I have ver 5.67 installed and just got an email announcing ver 5.68 for download and install. The CCleaner website says that a registered Pro version should update automatically. I update settings appear to be correct. Attached are my settings. Thanks.
Your update setting is fine,
With millions of users out there it just takes time to send the update to them all.
If, like yourself, you notice there is an update before its has been automatically sent to you then you can always update manually if you don't want to wait.
Just click on the 'Check for Updates'. (or download and install manually).
With most software it's usually better to wait for the automatic update to come through to you.
