Problem uninstalling resident evil, I have run cleaner and registry as the game would not play it still wont and now wont uninstall I re merged the back up but no luck. Can someone please help. It originally would not play because it said dxd3d_30.dll could not be found which was why I ran cc in the first place. PLEASE HELP IF YOU CAN
Hi sean, and welcome to the forum.
You could try a System Restore to a point before the problem started.
Or, you could try re-installing the game, which would hopefully replace the missing .dll.
If that's successful, and you still want rid of it, then you could try removing it with Revo Uninstaller after first making a System Restore point, although you can configure Revo to do that in "Options\Uninstaller".
Maybe if it's still listed in ADD/REMOVE, Revo may uninstall the game without the need to re-install it first. Worth a try, but set a System Restore point first.
Revo Uninstaller: (Freeware)
