MusicMatch V Winamp
Never goes over 3,000 K for me.
foolbar2k plays all those formats "Out of the box" because it comes with all the plugins already. Why have plugins for stuff you'll never use?
  • Balls-on accurate
    Plays the way nature intended
  • 32/24-bit & multi-channel output
    take advantage of supporting hardware for ultimate quality
  • Gapless output
    Gapless playback of all supported formats
  • Interpolation & volume/pan ramping
    For output that’s smoother than a baby’s arse!
  • DSP
    Automatic gain control (and Replaygain), 5 band equalizer, reverb, plugin support
  • Net streaming
    All supported file types (including MODs and archives) can be streamed from FTP and HTTP servers (inc. Shoutcast/Icecast/Icecast2), optionally writing a copy to disk, FTP directories and HTML webpages can be scanned for playable files
  • Track information
    Displays file/format information, messages/tags, and instrument/sample texts, open webpages from the texts
  • Title formatting
    You decide how you want the track titles to look, title updating from 'net streams and CUE sheets
  • Library
    A database of your tracks, for quick and easy access to the tracks you want to play
  • Saved/preset settings
    Save settings (DSP/etc…) to be automatically used each time specific tracks are loaded, save presets for quick application at any time
  • Disk writing
    Writes 8/16/24/32-bit WAV files, supports external encoders (MP3/OGG/etc…), optional automatic level normalization, dithering & noise shaping, individual MOD instrument writing
  • Keyboard shortcuts
    Fully customizable shortcuts, including global hotkeys
  • Integration
    Open files/folders from Windows Explorer, drag’n’drop files/folders/shortcuts/URLs, monitor the clipboard for playable URLs, drag’n’drop tracks from XMPlay into other programs, icon customization
  • Archive plugins
    Archived/compressed files can be loaded just like normal files
  • Unicode file support
    Support for Russian, Chinese, etc…
  • Visualisation
    Compatible with Sonique plugins, also includes a MOD pattern view
  • No installation
    UnZIP where you want and go!
I use Winamp v2.81, it is an old version from 2002.
It works good, it is nice, have everything I need.
There are Winamp 5 nowadays, but no people from the orginal Nullsoft team who made Winamp is in the current team of developers of Winamp. Justin Frankel (leader) quit too.
I'm also using a Columns UI format string that I completely customized.
I would make a config file myself but it all looks like gibberish to me :blink: , and the fact the config file i got is 98% of what i would like to make anyway.
Foobar does all those things. I'm not sure about your screenshot because that was no where near what I got on my system with it.(maybe others could say what xmplay uses on theirs. Also make sure your playing a file)
Like I said XMPlay does not have a good library function.If you have a small amount amount of music then it should be ok but if your like me and have a lot then that just isnt good enough. I want my music sorted by artist then album with a dropdown menu.(like my foobar is)
lol, it shows that it is playing just by looknig at the skin. Though I did see a lot of junk in your system list screenshot. Maybe that's why foolbar takes more. The library works really well; though there are a few features that I like that are missing. (Like pressing next with random on and it will randomly select a new song instead of going to the next track)
Btw, it also supports Winamp plugins; so you can probably fix the library through a winamp plugin too.
i get 7300 and change on mine while playing tuneage with foobar
I love coming to this site cause I learn about stuff I had no I idea was out there.
Question: Do either of these apps support seamless looping of a wav, mp3, or ogg (etc.) file?
Thanks
I believe XMPlay does. You can loop one mp3/track, or the entire playlist/library.
http://www.un4seen.com/xmplay.html
Hmmm, are there any music players where you can play one track on top of another track?
Thanks, I'm gonna look into xmplay. I'm always trying to streamline my system.
Media Player Classic with ffdshow(have to config it first)
Well, I tried out Foobar 0.8.3, and while it isn't by any means a poor audio player, I'm not sure it is what I am looking for. As much as I hate to say it, I still like WMP better than it. I have really gotten used to using my WMP toolbar so that I can switch tracks or adjust the in-player volume without having to restore it to the screen first. As far as I can tell, Foobar doesn't offer that.
I also thought the visualization window was tacky and of course the default appearance of WMP is far more refined than Foobar. These aren't major complaints, but they do count for something. Also, when using Foobar, I checked it under Task Manager, and it was using around 20 MB of pagefile, whereas WMP only used around 7. I know that rridgely said Foobar uses far less than that, but I wasn't playing a movie; I was simply listening to audio from my library.
I won't delete Foobar, as I still want to test it out some more, but as of now, I find that WMP is just a better player when it comes to the look, feel, and ease of use. And you don't know how much I hate to say that!
On a more pleasant note, I just realized that Tarun was listening to Ten Thousand Fists, Disturbed's newest album. Very sweet.
I like Winamp (2). :)
But yesterday I found 2 audio players on Wikipedia that I can imagine people liking.
* http://en.wikipedia.org/wiki/MusikCube
* http://en.wikipedia.org/wiki/WxMusik
It can be sized down to this: za-fb2k-small-22jan06.png
or you can just use it via the systray which has playback controls using the Default User Interface and with Columns UI.
The visualization window isn't appealing at all so I'd have to agree. However it can be completely disabled, and removed from the GUI via right clicking the menu area. FB2K wasn't conceived to be another WMP or Winamp, hence the reason it loads so fast and has a wide playlist area that makes it easy to see the artist, title and album without necessarily having to click upon the file properties. To each their own though, because I used Winamp for years and there wasn't any way to convince me that anything was "better" up until Winamp started having skipping problems in practically every audio file I played - hence my exodus to FB2K.
As far as player mem usage goes it does matter what type of audio format you're playing, e.g.; when playing Ogg Vorbis (.ogg) I've seen the mem usage go up 1MB or so however I'm used to seeing about 7MB usage while it's loaded and not playing a track, however that spikes to around 8.5MB when playing a track.
Thanks for that info, Andavari. I'm still testing it out, so who knows, maybe it will grow on me. I haven't hardly touched the options, so there could be a plethora of usefull little tidbits I never knew about.
And thank you for the links to those other media players, Eldmannen. I'll probably check those out as well.
Most of the options are already pre-configured during setup with good settings. I would however highly recommend that you download Columns UI and a few pre-configured format strings from the Columns UI website since it will take the bland default user interface to something very appealing and more useful. If you spend about one or two hours here and there playing around in Columns UI you should be able to configure the GUI to your own preferred look and ease-of-use. Mine is dead plain but that's how I like it. :)
damn, i wish i could engage in this software testing, but MY comp's PSU is dead and i'm waiting for it to come in, on like tuesday!
Winamp for me...
i tried MusicMatch JB before which came bundle with my Zip Drive... but remove it shortly...
Winamp for audio... and WMP for audio CD, movie clips and anything else...
my Winamp operates in the system tray and use about 3000K of resources...
why are you using WMP for CDs? Winamp can also play CDs...
actually no good reason... but thts what i always do...
