Msn Messenger Problem?
recently i updated my msn messenger(it asked me to),and for some reason its not working properly and i have no idea why.
when i double click the msn icon to load it up,nothing happens,but i can get it working by reinstalling it again which is a bit annoying.so every time i restart pc or log off i gotta reinstall msn
dont think my registry cleaners did anything..any ideas?
Forgive me if you have already been here XanaTos, but if not, there`s a lot of info on various problems with Messenger.
Link:
I installed Live Messenger a while back, and although I now use Skype, it worked fine at the time.
Hope this helps, :)
Regards
gonna check that now.it totally didnt enter my head to check out a site for fixing msn problems actually.cheers for the link,can call me Xan btw ;)
