MS DOS 6.2
Actually, that doesn't look right - shouldn't the screen shot have appeared there?
Direct link to image is this: http://img521.imageshack.us/my.php?image=image1rz0.jpg
When you double click that "setup" icon , does installing DOS prompt come then?
Yep - that's exactly when it happens.
Try to use command prompt to launch that "setup" program. Open cmd (Start>Run>cmd). Then type d:. After that type setup. Of course you have to press "Enter" after all typed commands.
Just tried that, but get the same error message.
I'm guessing I've hit a brick wall here - or is there any way of downloading another program that is similar to MS DOS?
Link to the screenshot:
Edit:
Just noticed CeeCee already posted the link. :rolleyes:
You cant install or run MS.dos on a windows system after ver 3.1 unless you set up a dual boot arrangement.
And is a dual boot arrangement easy to set up?
Here is the MS instructions
http://support.microsoft.com/kb/306559
Go to www.imageshack.us
At imageshack click the Browse button locate your saved image click Ok
Click the Host It button.
Once its uploaded, copy the code in the first box,
Paste the code it into a reply to this post
Whats wrong with just using the upload button when replying to a post, surely easier?
Easier yes, but you also use up your allocated disk space on the forums, I have 1.95mb for uploading however I'm only using about 37.65kb of it.
Just been reading about a free emulator to run dos games and applications in called DosBox. It fools any dos software into thinking it is running in dos.
http://dosbox.sourceforge.net/news.php?show_news=1
The FAQ's and downloads are at the top of the page.
Also available and recommended is D-Fend which stores your setting when you use the DosBox, this is available under the tools section of the downloads.
A music CD (not an audio CD) that's a CD EXTRA/Enhanced CD from 1997 wants you to install DOS? :rolleyes::lol:
What files are you trying to get off the disc, say a music video or something?
Wouldn't surprise me, the Iron Maiden remasters which were released in 1998 prompt the user to install some crapware by the name of Director Player that was probably released a few years before the birth of Christ. Even performing the sign of the cross to access the multimedia files didn't help. :lol:
