Hello,
Motherboard temperature doesn't work in 1.30
but is works OK in 1.29
I'm using motherboard temp in tray that's why this's important for me.
Please look at screenshots attached.
Thanks!
Hello,
Thanks!
the Devs will see your post and look into it.
until resolved, it looks like you'll need to stick with v1.29
Plan to fix the problem in next versions? thx!
unknown, sorry.
