Motherboard Temp Not Showing
Hi!
I opened up Speccy on my laptop and noticed that the temperature of the motherboard wasn't showing (Speccy showed the temperature only for CPU and Storage). I found it quite strange, since I clearly remember recently checking the temperature for the motherboard.
I checked for updates (my version was, if I recall, v1.30.728) and then I updated to latest version v1.30.730, but nothing changed.
Any idea what happened? Did the temperature of the motherboard get removed in a previous version without me noticing?
Thank you in advanced!
motherboard make/model?
OS?
Motherboard: Hewlett-Packard 1949 (U3E1)
OS: Windows 7 Ultimate 64-bit SP1
I found the same issue - but only after upgrading to the latest version 1.30.730
They have obviously changed something - no responses so far.
apart from some users having Speccy show no m/b temp, others (myself included) are seeing the m/b temp stuck on 28oC.
the Devs are aware of these issues.
