How about a Hot-key/Boss-key to Activate and Close CCleaner's window? Maybe we can even make CCleaner to clean up "Pre-set Items" in Silent-Mode with a Hot-key without even open the CCleaner's Window...
For example:
Just like the "Run CCleaner from Recycle Bin" function, but activated with just pressing: SHIFT/Alt + DELETE
OPTIONAL (allow us to turn off this feature in Option)
And after everything is cleaned, show a simple "Report of deleted Items window" and then automatically closed after 5 seconds... (with count-down display)
I hope this is not too much to ask, I know it sounds a bit crazy... but it will make our life a lot easier!
P/S: I got this crazy idea from AVG anti-virus + Run CCleaner from Recycle Bin!!!
