Microsoft ICE problem
Unfortunately CCleaner registry cleaner will cause 'Microsoft image composite editor' to stop working.
Microsoft XP (SP3)
Unfortunatly No reg cleaner is perfect and you should never willy-Nilly delete everything suggested even on a gentle cleaner like CCleaner.
Did you make a back up of the entries you cleaned? If so restore that backup, run ccleaner's reg clean analysis again and only clean the entries you KNOW for sure you don't need (see my signature)
