Hi, I am new and from Denmark, so I hope you will forgive my language.
I have used Ccleaner free for several years, and now I use it with windows 10 and the Edge browser. It's works fine, but there i a little bug. When i run clean, all fav-icons in the vertical favoritline disappear, and are replaced with "star". They did not come back by restart, but they are still normal in the horizontal menu under favorites.
When I open the horizontal line and click on one of the favorites, they all come back in the vertical line, but only to restart, then they are disappered again. The only way I can get them back, is to visit the sites, delete the icon and put it back with CTRL+D. Then they will stay to the next time I run CCleaner.
Any ideas?
