Microsoft Edge, 4 items SKIPPED during cleaning
After running Custom Clean using CCleaner Professional v 5.62.7538, the Advanced Report shows that 4 items were skipped during cleaning.
Microsoft Edge - Session
Microsoft Edge - Set Aside Tabs
Microsoft Edge - Saved Form Information
Microsoft Edge - Saved Cards
I tried unplugging from internet, rebooting my computer, and running Custom Clean again but it still skipped those 4 items.
Why won't it clean them?
Thank you.
Barbara
Likely cause is because Edge by default will pre-launch and pre-load when you start your PC.
There's a solution here has to be done by the user on each PC since there's no automatic fix implemented yet:
https://forum.piriform.com/topic/53177-how-to-disable-pre-launching-and-pre-loading-so-ccleaner-can-fully-clean-edge/?do=findComment&comment=302353
Thank you Andavari. I will give that a try.
Barbara
