Meta Cleaner!
Hello,
Could there be an added metadata remover? Perhaps it could be used to scrub the metadata on all files within a specified folder as well as for individually selected files?
I have a similar question, wondering how secure the "normal" file remover works. Is it the standard kind of erase that removes only the front part of a file, leaving the rest of the file searchable? Is it possible to do a multi-scrubbing kind of erase that prevents a forensic extraction of the original file, as some other programs do?
I re-posted this so I can say "thanks" and get notifications.
What? This isn't really a suggestion, is it? A CC normal deletion just runs the equivalent of a shift/del, so the file is flagged as deleted in the MFT and the data remains until overwritten. A secure erase will overwrite the data before deletion, one pass is quite sufficient.
Hi Augeas, do you mean to say that we have an option for a Secure Erase using CC along with the normal erase? Thanks.
Yes, Options/Settings/Secure Erase/Simple Overwrite
Fantastic. Great product. Silly me for not checking. Thanks again!
