Memorised Passwords and Logins Deleted.
I like CC Cleaner, but it deletes my memorised passwords and logins.
How can I avoid this happening?
Thanks.
Thanks.
Welcome to the forums Enrique,
Unchecking the "Autocomplete Form History" under Internet Explorer in the "Windows" tab should prevent your username/passwords from being deleted. I hope this helps.
Keith
You may find it is moving your cookies from the 'delete' side to the 'keep' side via the little middle arrow under ccleaner options>cookies that helps with this.
That is a good idea as well. Never used the include/exclude/cookies function as I generally dump them all but I will keep that in mind for future cases.
Keith
Thanks for welcome, and also for reply.
Does it matter that I use Firefox rather than IE?
Enrique,
Firefox's cleaning settings should up under the "Applications" tab then and would fall under the "Saved formed information". Uncheck that and you should be good to go.
You may find as will Enrique, that reading the info about what setting deletes what, of some help
http://docs.piriform.com/ccleaner/ccleaner...cookies-to-keep
As you will see here, moving cookies to the keep column can prevent your login details from a site being deleted when you run the cleaner.
Thanks.
I have same problem, and I still don't understand it. I have unchecked the cookies, as well as the
autocomplete form history. On the Applications tab, nothing is checked their either. After I run
CCCleaner, then I loose any settings that were previously saved.
Any help is appreciated.
Carl
Passwords and logins are also saved as Adobe and Macromedia Flash Cookies.
Cleaner > Applications > Multimedia > Adobe Flash Player
