Hello
After I translated the winapp2.ini correctly for my version of Windows XP, I found out that the MediaMonkey entries probably don't work correclty for my Windows XP German.
Are the informations correct for your version of Windows XP?
Under the German expressions I always translated the English ones using the ";", hope this helps.
[*MediaMonkey] LangSecRef=3023 DetectFile=%ProgramFiles%\MediaMonkey\MediaMonkey.exe Default=TrueFileKey1=%userprofile%\Lokale Einstellungen\Temp|.|RECURSE
;FileKey1=%userprofile%\Local Settings\Temp|.|RECURSE;FileKey2=%userprofile%\Eigene Dateien\Eigene Musik\MediaMonkey|MediaMonkey.m3u
;FileKey2=%userprofile%\My Documents\My Music\MediaMonkey|MediaMonkey.m3u;FileKey3=%userprofile%\Eigene Dateien\Eigene Musik\MediaMonkey\Previews|.|RECURSE
;FileKey3=%userprofile%\My Documents\My Music\MediaMonkey\Previews|.|RECURSEFileKey2=%userprofile%\Lokale Einstellungen\Anwendungsdaten\MediaMonkey|MediaMonkey.m3u
;FileKey2=%userprofile%\Local Settings\Application Data\MediaMonkey|MediaMonkey.m3uFileKey3=%userprofile%\Lokale Einstellungen\Anwendungsdaten\MediaMonkey\Previews
;FileKey3=%userprofile%\local settings\application data\MediaMonkey\Previews
The temp-entry did delete all my temp-stuff at this place:
FileKey1=%userprofile%\Lokale Einstellungen\Temp|*.*|RECURSE
;FileKey1=%userprofile%\Local Settings\Temp|*.*|RECURSE
I kind of was confused since I expected ccleaner to clean this place as well on a regular basis without having a MediaMonkey entry.
Is this place cleaned automatically having an English version of Windows XP without MediaMonkey entry?
This two paths MediaMonkey didn't install:
FileKey3=%userprofile%\Eigene Dateien\Eigene Musik\MediaMonkey\Previews|*.*|RECURSE
;FileKey3=%userprofile%\My Documents\My Music\MediaMonkey\Previews|*.*|RECURSE
The MediaMonkey.m3u-path is:
The Previews-path is:
;FileKey3=%userprofile%\Local Settings\Application Data\MediaMonkey\Previews
Might it be possible, that MediaMonkey changed it's paths during the years? I'm using it for a cuple of years now.
Or might it be that different paths are used for different languages of Windows XP? Or a combination of both?
The temporary path of MediaMonkey ist (entry found under ->Tools ->Options)
Thanks for answering my questions or any ideas or helpful information!
P.S.
If there are some Windows XP language issues, probably there are other applications that might not work properly.
