Maximum path length exceeded
I understand why this is happening, but to help minimize the many hours this is taking to identify which files are too long...perhaps add a small option to not just output the error of maximum path length exceeded, but put in a small script to show all the offending files and a link to them so the user can quickly get back to recovering all the important data...
Thanks,
Nathan
Hi Nathan, and welcome to the forum.
Thanks for the suggestion, and I wonder if this would be of any help in the meantime if you're still struggling with the error ...
http://forum.piriform.com/index.php?showtopic=38909
Hello
I get the same error.
Even if the File-name, Folder and Destination are all short.
Were can i download an older Version? I beleve the error is only since Version 1.4
Axel
Older versions are listed on the right-hand side of the page.
http://www.filehippo.com/download_recuva/
