Maximum path length exceeded
Last week I moved (cut and paste) my data from a hard disk to another. In the mean time the old hard disk was stored without any further action. Unfortunately, this new hard disk crashed, leaving me without any data.
In order to recover the data from the old hard disk I performed a deep scan with Recuva V1.43.623. From the scan results it should be possible to recover most of the lost data. However, when I try to recover the data (using the option "Restore folder structure") I get the following error: Maximum path length exceeded.
Can somebody plase help me getting my data back? It will be highly appreciated. THANKS!!!
Try a shorter path. G:\Files Or similar... Instead of using restore folder structure.
Instead of G:, use whatever drive letter you are backing up to.
