Map not updated properly during defrag
When defragging, the colored drive map should display where Defraggler currently reads (yellow) and where it writes (green). When it is working on small files this works OK. But when there are a bunch of large files (CD images, huge video files, ...) the green and yellow blocks often don't change for minutes, even if meanwhile a different file is shown in the status. In this case, only pressing Pause (and then Resume) updates the drive map. AFAIK this is new since v1.19.
I think this is what's discussed here: http://forum.piriform.com/index.php?showtopic=27788 as well. I don't feel that this is too annoying since the text gives me all I need to know.
No, it is not. That thread was about the map AFTER defragmentation not showing correct color (fragmentation status) of individual squares and content (how many / which files).
I don't think so. Especially when dealing with very large files, where each takes several minutes to be moved I'd like to know what's going on.
