Oi, I better download it then, in case the nuclear reactor in my basement has been compromised!
Have the men in black helicopters arrived yet
You and me both!
My memory is shot and I'm only 19
I wish I could remember 19.
I can't remember much from before about 9 years ago. spotty at best. The only memories I can recall well are ones from the last five years
I remember the good old times - they ended when when Windows arrived.
zing
I keep telling you, keep taking the pills. And if you run out, I'll send you some of mine.
LMAO
I am, I am, probably need a higher dosage. Also have changed my eyeglasses several times. Just wish it was possible to upgrade my memory like I did for old HAL here.
Again LMAO
Try some Ginkgo Biloba capsules (here's what Wikipedia states about it). Although I took it in the 90s I can't remember if it worked.
