Main window display problem
Defraggler retains its last used window size and position (including the position of the horizontal divider between the drive list and the drive map). However, it does not retain its column widths.
I am constantly having to resize the columns so that they fit the information and I can see it all at once. But as soon as I close and reopen the window, all of the columns all revert to their original (too small) sizing, whereas all other window elements retain their user-adjusted state.
I would very much appreciate a fix for this, in order to prevent the constant need for resizing the columns whenever the Defraggler window is opened.
Thank you.
