Mailwasher blues
Hi
I recently installed the latest version of CCleaner 2.17.853. Soon after, my Mailwasher program (for pre-viewing emails before download) started playing up with gmail accounts.
I have boiled the problem down to the following .tmp file being removed by CCleaner 'registry issues':
Problem: Missing MUI reference
Data: C:\DOCUME~1\<myname>\LOCALS~\Temp\is-RJ58H.tmp\Mailwasher_Pro_tmp
OK, what is being removed looks harmless .tmp, however, it is affecting the proper functioning Mailwasher.
Anyone else? (I see no option to 'permanently ignore' this entry in CCleaner.)
in the program you can go onto the options and go to the exclude file and add that file to the list of items for do not remove from system
