Luna Element 4
Luna Element 4
Supports Vista styles, and compact taskbar/menus, etc.
Fantastic Theme :)
How do u make it work ive downloaded it installed but when i go to LE4 in disply properties it doesent show the theme the way the pic does
-MacmillaN
Awesome theme, I'm using it right now.
Make sure you use the UXTheme patch, which can be found on the net anywhere.
my UXTheme patch killed my comp
right now i can only use Classic Skins. i tried to enable Windows XP's default skin but instead of blue taskbars, i get Classic. does this with every skin -_-
Thank You :)
does anyone have a working version of UXTheme.dll
i need one
i need one
http://www.softpedia.com/get/Desktop-Enhan...SP2-Final.shtml
i've already tried that. it doesnt work
edit:refer to my first post to see why it doesnt work
I did a google search and found this site:
http://www.dlldump.com/download-dll-files_...0/download.html
thats the same file
Mangix, I have been having the same problem, the dll that I downloaded was the same version as my original one.
Luckily the original themes are still working for me, although I had to select the windows xp theme and make all my own modifications again.
I am going to keep an eye on this thread to see if anything works for you.
@Tarun
Supports Vista styles, and compact takbar/menus, etc.
taskbar ;)
@Tarun
taskbar ;)
Payback! :lol::P
hmmm since im running out of options, im gonna try to Hex Edit the UXTheme patcher because it's being gay to me -_-
That's what I thought, it couldn't happen to a better guy, sorry Tarun. :D
@Tarun
taskbar ;)
Someone edited my post, I swear!
HAHAHA you wish! :D
Nice try.
Shame I can't use this, downloaded it, installed it, went to themes, and when you select it the preview is all black with a glimpse of the theme. Any help?
UXTheme.dll patch as mentioned above many times. :)
