Hello to all! I have always had great results with CCleaner, great product! I'm an intermediate PC user, fairly literate.I'm using Win. Vista, Home Prem., SP2, 32bit. I always have lots of reg. issues, esp. after waiting a while to run reg. cleaner. I've only used it a few times and haven't run into any problems which I think are caused by CCleaner. The question is; why do I have so many reg. issues? Most are "installer" issues and even the other issues usually say "value left behind after uninstalling software" or something to that effect, even though I haven't uninstalled anything! What's going on here? One issue I do have is that my facial recognition program I have, in lieu of having to type in my password when booting, doesn't work anymore but it started not working before I ever used CCleaner's reg. tool. Anyway, here's a .txt file of my issues if that helps. Also, would I have to restore ALL back-ups which were cleaned if I do have an issue after using the tool? Thanks for any answers, appreciate it.
Ranchman
