Lost loggin info when cleaning my registry
Hi Guys,
Just wondering if anyone can help me with a little problem I've developed myself!! I recently ran CCleaner on my wifes computer and subsequenty have deleted some of her loggin info for some sites she was one. Because her computer would autofill in any usernames and passwords etc, after I cleaned the reg she can't get logged on. I went to the backup registry and done the whole "merge" thing but didn't make any difference.
Can anyone let me know how to get this info back
Thanks
P.s. also I keep getting a constant error message of "TFncKy has encountered a problem and needs to close. We are sorry for the inconvenience." again i've ran mulitple cleaning tools but can't seem to rectify this problem so again all help would be greatly appreciated!!
Thanks
You should post this in the CCleaner/Software Discussion. By the way, those file can't be recover
Thanks
Hi Steve,
Welcome to the forums !!!
You have two problems to clear up. The second problem is unfortunately bad news.
1. Use the links at the end of this post to help you decide what to do about "Autocomplete Form History " , "Cookies" and "Flash Cookies" and CCleaner itself.
2. From what you describe, you may have malware or the remnants of it on your computer. You need Expert help.
Go to this link immediately and follow its instructions. Do not do any more cleaning or installing until you get your PC cleaned of malware and verified by our experts.
http://forum.piriform.com/index.php?showtopic=17457
Do step 2 FIRST. It is that important to your security.
Good luck,
:) davey
http://www.ccleanerbeginnersguide.com/
CCleaner Beginner's Guide.com Bookmark and save to Favorites
New members Advice for CCleaner
Start here with this link and follow its advice.
http://forum.piriform.com/index.php?s=&amp...st&p=105208
Also see this link about the Registry and Registry Backups.
http://forum.piriform.com/index.php?s=&amp...ost&p=96510
