Lost everything HELP
I was surfing the web for about 2 hours this morning. And as i usually do when finished I will run a disk cleaner. This morning my pc froze and stall on and i had to do a hard reset. When i started it up again every thing was gone, it looked like it did 6 years ago when it came out of the box. I am running recuva as we speak it has been running 3.5 hours trying to recover 49,000 files. When it is finished will i regain every thing and what should I do To get it back in the condition it was when this happened. I do not have system restore enabled. Thank you
I see you mentioned something similar here
http://forum.piriform.com/index.php?showto...mp;#entry128469
By the way are you still using Clean Disc Security you mentioned once that you were using?
Thank for your reply, and i am still using clean disc security. The recuva has run to finish, and if I do a search on something that i know , it will find it in the folder that i did the recuva in but it completely filled my hard drive which is 80 gig. But nothing is where it was before the problem?????
Thanks again Al
