Missing audio driver after ccleaner installed driver updates
Try the “+ Fix a problem” button:
If that doesn’t/can’t help then you could try doing a Windows update by using Check for Updates in settings, that should bring in any drivers needed.
If that doesn’t work then you can try manually loading a new audio driver through Windows Device Manager:
Update drivers tusing the Device Manager in Windows:
Microsoft Support
