Can you suggest any recovery application ASAP?
Frantic at the moment.
thank you. Avie
thank you. Avie
How did that ever happen? You must have added some custom ini entries cos that certainly isnt default behaviour.
Data loss not fault of CC. I had deleted the contents of one "My Documents" know there was same contents in other. All went out to never land, I though. Mentioned this because I ran CC with maximum erasure and thought all would be lost. However, fortunately I found a computer guy who restored the data with his Ontrack software. How about that happy ending. I am passing this along to everyone who may have similar experiences.
I am having trouble with deleting several programs. ( Lavasoft's) Even wnet through registry. CC has uninstall but is not able to to it or nor can I remove from list. Any help with this?
Please and faith client for you product. Thank you so much.
Avie
try Your uninstaller 2006 or smarty uninstaller ..
Thank you for your suggestions.
Re-installing over the already installed application, or doing a repair install of any applications that are having problems or won't uninstall is also a very easy fix.
