Loss of license key aftter cleaning
After cleaning, I can not longer use my Delphi program. The license key is missing.
I tried to restore the registry database, but I received an error message stating that not all the data
If you have messed up the registry and are unable to restore it then you will have to reinstall the affected programme(s) to reset the registry entries.
PS. There is not usually any need to clean the registry if you are using Windows newer than Windows 7.
Microsoft recommend that you do not use any registry cleaner:
Fees is required for new registration
I am not satisfied to pay for a software unsafe
Any tool is unsafe if used incorrectly or for the wrong job.
