Losing Folder settings
After running Ccleaner I have to reset all my folders on my Desktop. I have them on List but revert to Details, Icons, or Thumbnails. To get them on the same page, I have to reset about 4 or 5 of the Folder Options in the View tab. What do I need to uncheck on my list of WINDOWS list. I have all checked except Menu Order Cache and Wipe Free Space. Thanks
Uncheck "Custom Files and Folders" and "Windows Size/Location Cache".
Do not check things you do not understand.
Link from CCleaner help that explains what each option in the "Advanced" section of CCleaner does: http://www.piriform.com/docs/ccleaner/ccleaner-rules/windows-tab/advanced-windows-files
Custom Files and Folders would have absolutely nothing to do with folder settings unless someone inputted folder.ini files, registry locations, etc., which seems unlikely. There is a "bug/limitation" in at least some XP systems where it will very quickly forget folder settings - it's super annoying too.
