log-files removement problem
our problem with ccleaner is the following: it removes all *.log files, but
there are the following string in ccleaner.ini
(App)Windows Log Files=False
Exclude1=PATH|%systemroot%\system32\logfiles\|*.*
in the previous program version the situation was the same, but it was solved by removing portable.dat file
from ccleaner program dir (i think ini-file was ignored). now we cant find any problem solution...
