Lockup on start
I have tried Speccy on several PC's and it works well, but on my home laptop it shows the start screen with all components "Analysing...", but there is stays indefinitely. If I switch to another app and switch back then the screen is not redrawn and it remains white. This is on XP Pro SP3. Is there anything that I should try?
Post your system specs and run the debug mode to post what is going on.
AJ
Very ironic - providing system specs for a system spec program! ;-)
It's Windows XP Pro SP3 with IE 8.
Laptop is a HP NX6110
If I run Speccy.exe /debug then two empty files are created in the same folder named:
Speccy.exe_<date>_<time>.dmp and Speccy_log[1_00_057][<date>_<time>].txt
What else do you need?
