Currently on 5.46.6652 and I have had the issue of loading with windows for several ver. now. I am tempted to revert back to an older ver. to avoid this. However, I really don't reboot my machine that much so it's just a minor thing for me, yet very irritating.
@Slim i've made you a new thread as this topic is concerning a different issue. In your own thread your problems can be better served.
Can you describe better "loading with windows for several ver. "
@Nergal Thanks.
The option in the image attached for "Run CCleaner when the computer starts", having it un-checked doesn't prevent this from happening.
Thanks, Slim
That setting actually means run cleaning at start-up. Is it cleaning or just starting at boot? If the latter, then make sure on 5.46 that smart cleaning (was monitoring) is turned off. This may fix your ccleaner starting with windows
4 hours ago, Nergal said:<div class="ipsQuote_contents"> <p> That setting actually means run cleaning at start-up. Is it cleaning or just starting at boot? If the latter, then make sure on 5.46 that smart cleaning (was monitoring) is turned off. This may fix your ccleaner starting with windows </p> </div>
Thanks, this was my issue and I am grateful you were able to assist me.
Slim
