Less than 10% warning bug
1. Remaining space less than 10%
2. Warning about cleaning 20 GB from the bin
3. Remaining space after cleaning 14%
4. The warning of 10% appears
I think is obvious the bug, isn't it?
UPDATE: watching closer I think all have to do with the file list creation.
file list creation?
are you running with wipe free space checked off? this will sometimes create space eating
what gives you a warning about "cleaning 40gb from bin"
what occurs if you empty the bin normally then cclean?
OS and Ccleaner version number
If you Right click on bin icon/Properties/click C: drive, you will see the size limitation-
Mine "was" Default at 7047mb, for a 100gig C: HD ( I ticked Remove Immediately, with a final warning...)-
You are probably Way over with 40gig, unless you have a Huge C: drive!?
BTW- No files are 100% deleted until After a reboot, and it "seems" to finish up... After next days cold startup (My WD Raptor HD(4gig Ram), hyper-clicks...).
I never Defraggler on a cold startup (or anything else- net will be Slow...), and only defrag After a no-activity 15min wait reboot (7-passes, just like Win Defrag is Super Performance for me) I wait for 7-min for normal computing, after 1st reboot)).
-If you are skeptical?- Analyze on cold startup, then again after a 15min reboot (you Will have hundreds fewer fragments, and usually no left-overs at end-of-drive).
If I do have leftovers, or any red boxes- I click on All of them/ defrag/Analyze, and more full passes (until defrag takes 2sec...).
