Last Two Versions of CCleaner Free will not Load
I've used CCleaner Free for a long time now without any problems. Suddenly, when I've downloaded the last two versions, neither wanted to open and a window opens telling me that "Windows cannot access the programme. You may not have the appropriate permissions for access".
When I go to properties and security, although the appropriate permissions are ticked, they are greyed out.
Any help/advice would be appreciated
What operating system are you using?
Are you downloading Ccleaner from here? (recommended)
https://www.piriform.com/ccleaner/builds
What anti-virus do you use and is it up to date and all scans report no problems?
I'm using Windows 7. Yes, I downloaded from the Piriform web site. I use Bitdefender Internet Security which is up to date and is reporting no problems.
Make sure Ccleaner is uninstalled.
Check that there is no instance of Ccleaner running in task manager after the uninstall.
Download (but don't install) a new version from the builds page (use slim build)
Then boot into Windows safe mode and install Ccleaner. (ask if you need a reminder on how to do this)
Does it run in safe mode?
Boot back into normal mode and then try Ccleaner again.
Does it run?
Here's the link to the builds page:
http://www.piriform.com/ccleaner/builds
I to, have used this program for years.... and now the last couple of version refuses to install..
something wrong somewhere.
I did download the slim, and click to install via admistrator , it pop up, to start the installing.. ( click cancel )
so, there something wrong with the main app... very odd.
First time I have seen this.,,using version 5.02.5101 64 bit.
can not upgrade.
No, at a guess, it's that your antimalware or other security precautions is blocking the google installer, which is there to keep ccleaner free. the slim build doesn't have it but isn't available for the first few weeks of release.
No, I think you are wrong on this... I been running the same set up for over a year... have not had any problem with installing the newer version over the older version.. even before that... had a setup for 3 years the same with security apps installed... nope.. no problem with the installs.. as I said.. something has change in the last few updates... that it throws that error message as stated above.
This is a first for me... So, if there something else ccleaner is doing, well its not working... like it use to be.
please be advised.
Regards -
Jusy because previously it worked, does not change my theory that a security definition is at the root of your difficulty
If you boot into safe mode and install ccleaner does it run then?
The slim version of build 5.04.5151 has been out several days now.
You might give it a try, although you said in post #6 that you had already done that.
As described in post #4.
Keep trying, someone on the forum will know how to get it to install. :)
Have a read here for solutions to install problems:
http://forum.piriform.com/index.php?showtopic=5739
Also that solution topic details how to use the portable build to update over a pre-existing installed build.
I also have been using CCleaner for years; but had been LAX in updating it. Recently I decided I should update. On installation the main screen would LOAD but no buttons were active. To stop it I have to use Task Manager. Thinking it was a new problem, I found a site with back level download. I tried 3 Version 5 releases, same issue, then downloaded and installed 4.19 (the oldest version I could find) All exhibit same problem. Currently I am attempting to UnInstall 4.19 (using Control Panel) That process is hung in the middle of uninstall). I use AVAST anti-virus, have an active system monitor Mooo and am evaluating Wise 365. My intent (if I can get 4.19 UnInstalled is to re-install current CCleaner in safe mode as Administrator then try to run it. I am running Win 7 Ultimate 64. Would appreciate any other suggestions.
Update: Safe mode install as Admin worked. Ran in Safe mode and again in normal mode with most current version.
