myke35
January 27, 2020, 10:18am
1
Hi,
Always used CCleaner on my Kindle Fire HD 8 but I can't get it to work on my Kindle Fire HD 10. When I click Analyze Files CCleaner just closes down.
I had a look and CCleaner has Storage permissions.
Just wondered whether anyone's come across the same & whether there might be a solution?
oldhew
October 5, 2020, 12:38am
2
I have the same problem on my Kindle Fire 8. CCleaner has always worked well before this week, but suddenly it quits just as you said. I don't know of a solution.
I'm not entirly sure so call this a semi educated guess.
I suspect that it may be because the Operating System of a Kindle Fire is not truly Android.
It's a Unix/Linux type OS that is based on Android open source but modified by Amazon.
So any changes and/or updates made by Amazon may suddenly cause it to have problems with apps that are designed to run on true Android.
Did your Kindle get an update recently?
https://en.m.wikipedia.org/wiki/Fire_OS
