Kamo and Edge Chromium
Does Kamo support both the old Edge and Edge Chromium? I can't really tell which one it is saying is protected, since the old one apparently stays in Windows unless you remove it manually.
54 minutes ago, gesokynu said:
https://community.ccleaner.com/topic/59555-kamo-questions/?tab=comments#comment-325073
Thanks for directing me to the information. Is there a reason there hasn't been a Kamo forum added?
Probably because there are not enough users.
