I`m getting K hardware interrupts line in the task manager with no abilty to check anything on this through the task manager, does any of you have any idea whay is it there all the time and for what purpose? Thanks.
Incorrect title.
The "K" is Kilo as in Kilo Bytes.
That image looks like Process Explorer and not Task Manager.
I got 5550 search results from the phrase
hardware interrupts and DPC
This explains what DPC is
https://en.wikipedia..._Procedure_Call
This is an example of too much interrupt / DPC
http://forums.majorg...ad.php?t=229157
You appear to suffer less than 1% of the CPU usage that caused grief at
Incorrect title.
Hi Alan
The image Indeed is from process explorer.Thank u 4 the links Alan, BTW 2nd and 3d links are the same.
You are welcome.
NB the third link was conveniently in my paste buffer so I repeated the link instead of referring to "the above".
