bonjours j’ai un abonnement actif mais la clé de licence est arrivé sur mon ancienne boite mail dont je n’ai plus accés comment faire svp
You will need to contact support and ask them to change the email address registered to the account.
All customers MUST now access a ‘Live Chat’ support service. It is the only way to access support.
it should also open a ‘Live Chat’ where a virtual assistant will try to help you.
Note that you HAVE TO engage with the chat if you just fill in the form and leave then you will not get a reply.
