Java 64-bit error when attempting to run Minecraft
UPDATE: Problem has been fixed.
I've been trying to play Minecraft today after I installed 64-bit Java (haven't played Minecraft for a while, nor have I had Java for a while, only installing it for Minecraft), and when I try to run Minecraft, I am getting this error:
I've gone into Google and have looked up this error, and one "solution" I've found is this one, located here: http://www.neoseeker...19-64-bit-java/
For Windows Vista/7:
Click Start and right click 'Computer'
Choose 'Properties' from the menu
Click 'Advanced' or 'Advanced system settings'
ii) Click on Environment Variables.
iii) Under System Variables, scroll down, find 'Path' or 'PATH', and click on it.
iv) Click the Edit button and then scroll to the front of the edit window, and paste this:
C:\Program Files\Java\jre6\bin;
v) Click OK->OK->OK
If using JRE7 then replace 'jre6' with 'jre7'
Unfortunately, that doesn't seem to have done much for me at all, maybe I'm doing something wrong, not sure. If anyone has any ideas for this, that would be great.
Another thing that I have tried doing is adding a system variable like so:
But that doesn't seem to have done anything either.
You need to install the x32 JRE alongside the x64 one.
Won't that still mean that Minecraft will utilize the 32-bit installation rather than the 64-bit installation? The reason I want it to use the 64-bit installation is because there is a message in the options area ingame that says a 64-bit installation is recommended for a Far render distance, stating that I have a 32-bit installation rather than a 64-bit.
The error message is specifically asking for a 32bit JRE install. Always do what the computer says, regardless of right or reason.
Try following the steps in first post here
*removed link
On 11/07/2012 at 17:08, hazelnut said:
	<div>
			<em><a href="http://forum.precipicegames.com/suggestions/running-minecraft-using-64-bit-java-a-tutorial-by-a-noob-for-noobs/?PHPSESSID=s4jife707ecd982avt5euuu9j4" rel="external nofollow">*</a>removed link</em>
Tried that one as well Hazel, thanks though.
I run minecraft with just the 64bit version. (Java 7 Update 4 (64 Bit)) I am a bit out of date, but it works. https://dl.dropbox.com/u/14823386/sd/2012-07-11_143016.png
I run minecraft with just the 64bit version. (Java 7 Update 4 (64 Bit)) I am a bit out of date, but it works. https://dl.dropbox.c...7-11_143016.png
I'm trying to do the same thing, except I get the error message shown in the first post. Any idea how to fix it?
Have you tried doing a full uninstall (Shane's JavaRA can help you with that) and reinstall of Java?
Yep, and using JavaRA.
Have you tried re-intalling Minecraft?
Info here in case you are unsure how to do this (although I'm sure you are :))
http://www.minecraftwiki.net/wiki/Tutorials/Minecraft_Help_FAQ
http://www.minecraft...ecraft_Help_FAQ
No luck, I can't even start the Minecraft.exe file to re-download Minecraft. :(
have you tried installing 32bit java? :lol:
Yep, works fine with 32 bit. However, you say you're using only the 64-bit which is the same thing I want. Before anyone asks by the way, yes, my computer is 100% 64-bit.
Strange, try installing 32bit Java, re-installing Minecraft, uninstalling 32bit (leaving you with 64bit) and see how that goes?
No luck. I tried uninstalling everything, all Java, all Minecraft, everything. Then I re-installed only Java 64-bit and then re-installed Minecraft, and still, the same error. Maybe it's something in the registry, I don't know. This is honestly quite frustrating. :wacko:
Sorry about the double post, but the problem is fixed. I believe it was something that was wrong with my Minecraft launcher, I redownloaded it from the website and it's working now. Wonder what was wrong with (5 words that start with w in a row :D) before, but it's all working now, yes!
Sometimes computers like to be spooky :lol:
Glad you got it sorted!
Another variable CLASSPATH also defines the classes and libraries for Java. This is important for both running as well as writing and testing Java.
