Issues with 2.00.500
Hi all,
First when I installed CCleaner 2.00.500, when I'd start it, it would show up in the taskbar but the actual window wouldn't display. I had to right-click the taskbar box and close it.
I uninstalled and re-installed, and now it's working, except that nothing shows up in the Tools window, where it usually shows programs to uninstall. Nothing shows up in the Startup tab of that window either.
I don't know if it's pure luck or what, but it's not finding any registry issues, and I've never had that happen before either.
I'm running Vista Home Basic with all the latest Windows updates installed. I have Avast antivirus and the Windows firewall. Not sure that it matters to CCleaner, but I am using Firefox 2.0.
Thanks for all your help!
Hmm, I must be the only one having this problem? I've installed an older version until this gets fixed.
Still nothing under the Tools menu with 2.01.507. This is frustrating.
