When I run Issues in CCleaner, I get a columns marked Problems, Data and Registry Key. I don't understand what the problem is and after I run the cleaner, the next time I get the same problems. So can someone explain, please?
First all, don't repeat your same quotes, it's kind of spam-y
The issues tab needs to be done several times no matter what your system. Simply right click, "select all" and run the cleaner. Every single time the list will get less and less. You don't have to do until it reaches 0, though.
