Issue to restore
Hi,
I deleted a file from a tvix device using its samba interface (network). I plugged the device using its USB interface, Recuva is finding the file although it has no names displayed (size is ok, but path is /?). When I try to restore the file, recuva is having an exception generating a false "access denied" error.
I attach the dump generated using the debug mode.
Can you check that ?
Thanks for your great tools.
Recuva_log1_39_5093-2-2011_23-0.txt
Recuva.exe_3-2-2011_22-01-22-468.dmp.zip
