Hello-
When I run an issue scan the results shows uneeded file extensions such as .exe, .com, .pif, etc. (Screen print attached)
Are these safe to delete?
Thanks!
Hello-
Thanks!
yes, it is perfectly safe. If windows needs it, it will simply make another. be sure to alwase make a backup just in case. ( i personally have never had to restore a backup registry because of CCleaner)
)corjello(
Thanks corjello for your help and quick reply! I really appreciate it...
