[Issue] Outlook passwords will be deleted
Hi,
For some time will be deleted all my Outlook passwords, when I'm using CCleaner. I use Office 365 and in CCleaner I have to stand Office 2013 and Office 2016. I tried it as I selected both things, also I tried it as both things were not selected and in every case will be deleted my Outlook passwords.
How I can fix this for the future again?
are you referring to your email account passwords or the password on your PST file that is asked for when first getting into Outlook?
I don't have any pst files. I have ost files because I'm using Office 365 (Outlook 2016) in combination with Microsoft Exchange, which is checking my mails. I access directly to my different email accounts.
ok, but I'm still not sure what password is being lost by CC.
is it the password to access your email account or the password to get into your OST file (if you have setup a password to access it)?
in one case it is a outlook password to access my email account. in the other cases it is the normal password to access the email accounts.
I guess you have to untick: Cleaner > Windows > Windows Explorer > Network Passwords.
from what I can gather, you are losing your email account password when running CC - correct?
from my experience, CC doesn't, and in fact cannot, touch any password associated with Outlook, albeit the PST/OST access password or any account held within Outlook and for that reason - the are internal to Outlook.
we are talking Outlook, the desktop app, the program that's part of the Office suite aren't we???
and not Outlook.com, the website for checking some office365 accounts if you set it up that way?
yes, I'm losing my email account passwords when CC was running.
I don't know where Outlook (desktop app) is saving my passwords but if I just analyze it in CC then I get different entries in "All Users\clienttemplates.content.office.net", "All Users\odc.officeapps.live.com", "All Users\officeclient.microsoft.com" and "All Users\p.pfx.ms"
in total I get a count of 67 files.
all the time I am talking about the desktop app of Outlook in Office 365.
At the meanwhile I've tested it too on a clean Windows 10 about VMware. I just installed Office 365 and CCleaner and set Outlook (desktop app) up just like on my PC. I could reproduce the same error as well after CCleaner was run.
Did you try this? If you are using Exchange the passwords are stored in the Windows Vault.
You can check that: Open the "Credential Manager" ("Control Panel" > "User Accounts") and you will find entries starting with "MS.Outlook" or "MicrosoftOffice".
CCleaner deletes the Windows Vault if you enable "Network Passwords"!
yes I did it and it will be deleted in both cases and its reproducible.
Do you have those entries?
Please copy the following line:
REG QUERY HKCU\Software\Piriform\CCleaner >%USERPROFILE%\Desktop\cc.txt
Open a "Command Prompt" and paste the line into it.
Press "Enter", and on your Desktop appears a new file called "cc.txt".
Open the file, copy its whole content and paste it here.
I have been having the exact same problem. The saved passwords in my Outlook (via Office 365) for each of my email accounts were being deleted. When I unticked the "Network Passwords" box under Windows Explorer category this stopped this nuisance action.
