Is there a way to make defrag map squares smaller?
The squares in the defragment map are rather big.
Is there a way to decrease the size to 2x2 (or evem 1x1) pixel?
If not: Can this feature be added to the enxt release?
Thomas
Click on drive map then click edit settings. Click custom view and you can then set block width and height. This works fine on version 2.02 and lower. I have had problems since 2.03 getting the program to remember my custom settings.
