Is there a way to deselect "Cookies" permanent from Health Check
Is there a way to deselect “Cookies” permanent from Health Check?
If the cookies is deleted I loose all logins and saved passwords in Firefox.
But it is selected as default every time so it’s easy to forget to uncheck it.
Yes you can do that from Health Check.
Run a Health Check scan and on the first results page click this:
You then get a choice of how to put the cookies you want into the ‘Allowlist’ so they don’t get cleared:
If you choose to add your (some of) your bookmarked sites, and/or add (some of) the frequently chosen sites then you will be given another window in which to choose which ones you want to allow:
Note that if you cannot see the two buttons at the bottom of that pop-up window it is because of your screen resolution/magnification in the Windows settings, if you don’t see those two buttons then you will need to temporarily put the Windows setting to standard while you add the cookies to the allowlist.
