Hello people,
I'm quite new here and didn't read all the past post..
Well I'm asking whenever if it is possible to add a registry defrag to Ccleaner..
Thank you,
Shiw Liang
Hello people,
Thank you,
Shiw Liang
If you were to search the forum, you'd find this has been asked a number of times and everytime the answer is the same:
Registry defragging is a Myth and does Absoultly NIL when it comes to computer performance
I take registry defrag != registry packing right?
I mean. Packing the registry using the eruNT tool is also a waste of time?
If you mean physically defragging registry hives on disk, you should post in the defraggler section instead.
Some corrections and observations:
AFAIK Defraggler does not defrag files in use by other programs or the OS. Not to be confused with reg compacting.
Over the years I found that while compacting the reg would save some disk space, it would create numerous file fragments. Even using Diskeeper would not defrag the reg files, so compacting them seemed pointless.
I had better performance leaving well enough alone.
There are some utilities that will compact and defrag upon a restart. But I realized I was spending too much time performing maintenance and less time being productive.
With the exception of getting a new pc and removing 12+ programs, I dont see the need to perform reg compact(s) on a repeated basis.
Oh I see thank you for your attention
