Hallo Forum
I read about CCleaner, and have a small (Perhaps funny Question)
I use Firefox with IE Tab on Vista ...
Is CCleaner "most" build for IE or is it just as usefull on Firefox?
Well - It may be written somewhere - I just want to know for sure before I download.
Greetings J?rn
It will clean temp files etc from Firefox and IE so you shouldn't have a problem. Just select any cookies you want keeping in CCleaner's Options>Cookies (to save you having to log into sites you've saved login info for).
More info in the beginners guide:
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
Hi JDPower !
Thank you for your trustful answer and the Beginner Guide.
I will download CCleaner, who seams very useful !
