Interactive Drive Map
Is the graphic interactive drive map a real representation of the data on the disk?
I ask because I have run a defrag and compress program called DIRMS and after the DIRMS compress
compleats and I again run Defraggler, there is no difference at all in the drive map. It still shows a lot of space between files.
The attached image is after DIRMS compress compleated.
If you want to close the gaps then you need to defrag free space.
Richard S.
Richard, as you can see from image2.jpg I ran defrag free space and the "Gaps" are still there.
So my origional question is still open.
I completely uninstalled Defraggler V1.20 and then reinstalled it with a fresh copy. I see a small improvement in the drive map but still many gaps. And this is after Defrag free space.
My OS is Win XP pro with SP3.
new image included.
