Installing CCleaner on thumb drive
Sorry for the newbie question but I am curious if CCleaner adds registry entries to my Vista pc when I install it on my thumb drive; it does add itself to install/uninstall programs. I am looking for something that I can run from my thumb drive only and does not install anything on my pc.
Thanks
Use the portable build from the 'Other Builds' link on the download page. This will install (and run) quite happily on a flash drive.
Thanks!! I did just that.
This is probably a new topic but I noticed that it does not clean/recreate "all" the index.dat files in regards to the ones found in cookies, history etc.
For me it cleans
C:\Documents and Settings\Me\Local Settings\Temporary Internet Files\Content.IE5\index.dat
C:\Documents and Settings\Me\Cookies\index.dat
C:\Documents and Settings\Me\Local Settings\History\History.IE5\index.dat
C:\Documents and Settings\Me\Local Settings\History\History.IE5\MSHist012008123120090101\index.dat
and leaves 10 others, but most if not all of these are not active. I am the only user so others may have more complex combination of index.dat files. I don't know how CC decides which to clean and which not to.
I does but it requires a computer restart (or maybe just a user logoff I don't know) to take effect
Locations are a little different in Vista as opposed to XP and it only cleaned 2 of the index.dat files and there are 2 (or more) that also contain information in regards to the Internet.
