I am cleaning a WinXP Media Center system that had some malware issues and memory problems. The malware was removed and the bad memory was removed from the system. I think some installations may have been interrupted due to the bad memory shutting down the computer at random times with a BSD (blue screen).
Anyway, after running the Registry CCleaner program and removing a few hundred issues... it is left with 11 Installer Reference Issues and it says they're fixed but upon rescanning, they are still there. So CCleaner is not able to remove these remaining Installer Reference Issues, even as Administrator. Any ideas on how to remove them?
(see attached image)
Thanks in advance!
